bryan847
I have two questions about koush's official CMW! I did not realizew they could be installed over each other so I installed HashCodes tweaked bootstrap that runs from BP tools. I learned afterward that you can install the one from Rom Manager and install the tweaked one over it. So can i install the original over the tweaked? Or does it not work that way?
My other question has to do with making backups using the new CWM... Koush said that his bootstrap allows you to backup to external or internal sd cards... does the tweaked not let you do that? because when I try to backup it says cannot mount /sdcard, (because I dont have an external sd card!
Thanks for any help,
Bryan847
Bryan847
