nubreed000
Hey all I have some potentially stupid questions about installing CM7 on my phone, but I'd prefer asking them than risk bricking my phone so here goes:
This is the guide I'm using to install CM: How To Install CyanogenMod 7 On Samsung Galaxy S2
Anywho, I have installed ClockworkMod (free) and created a recovery.
I copied a stable version of CM into my root folder (update-cm-7.1.0-GalaxyS2-signed.zip)
Now with regards to installation...in the guide Step 3/Step 4 say to "Reboot into Recovery mode" so I click that and the phone resets into into "Android System Recovery"...and this is what I see:
...whats up with the errors there while installing the package? Is that supposed to happen?
Android system recovery <3e>
Enter: OK Key, Select: VOL UP/DOWN
reboot system now
apply update from sd card
wipe data/factory reset
wipe cache partition
-- Installing package...
Finding update package...
Opening update package...
Verifying update package...
E:failed to verify whole-file signature...
E:signature verification failed...
Installation aborted.
