1. Why is the internal storage referred to as SD card and the external Microsd card referred to as ext SD? Its confusing.
2. I can't seem to load any programs onto my microSD card. They all load to internal memory and none seem to be movable.
3. Is anyone running the app App 2 SD on their Relay? If so, are there any apps you had problems with after moving to MicroSD?
Sorry for the repeat, but I was hoping to get some feedback on these.
