questions about os 4.0.4 .232
ok, figured out the auto wifi turn on. problem solved
just need to figure out how to add widgets.
and turn the keyboard vibration off
anyone?
anyone?
The app drawer has tabs at the top. One is your apps the other is widgets. Tap the Widget Tab, find the widget you want to add and long tap the widget. Very simple and clean.
BigRedGonzo
google didn't help very much. but i musta been keywording wrong.
got it all figured out finally. i really hate learning new software versions. LOL
muchos gracias
