Root Questions about ROM and FAQ
Guys I'm using this phone since 3 months and its cool :) Now installed CWM recovery and flashed Dark Angel V1 ROM ! I have a few questions :
1. What happens if I try to do the reset phone in privacy settings??
2. Adb not working in dark angel ( windows 8 ) Worked with stock ROM before though.
3. Is a class 10 Memory card worth for this device?
4. Our new year gift is a custom ROM ? :)
5. Why do other earphones like samsung doesn't work? Are there any pin difference in the 3.5mm jack because I could hear only a karaoke??
1. It will remove ur gmail account and sync
3. Using a class 10 mmc is not recommended.. I use class 4..due to write speed compatibility problem
4. Guess so xD
5. Cause they have modified pins..for use with their products only..
It happens with all types of phones..of big brands
What I meant in the first question was as I have changed recovery and the ROM will v get back the same rom (using currently Dark Angel) ?? Btw for the last question do v hav any other gud brand earphones which work with this phone??
first answer - yea we have a stock rom and stock pre-rooted rom here on androidforums.com
last answer - I use skullcandy...my friend uses a JBL in the ear
use common brands like creative,phillips,jbl,etc
dont go for nokia,samsung and all..
btw if ur rich enough
go for beats by dr.dre or bose
