MrDeepFreeze
Here are the instructions from the S7 Weebly site and my comments or desire for more information.
1. Downloading the files is no problem but do I also need drivers for my phone? Where can I get them?
Can I start with an AT&T Captivate that is NOT rooted and has been upgraded to the official Froyo 2.2 build FROYO.UCKB1?
2. Open Odin3 1.7. No Problem
3. Select the PDA, PHONE, CSC, and PIT files in their correct spots.
I think I've got this as I'm just clicking the buttons and choosing the files I downloaded that start with PDA, PHONE, etc. but I'd like to be sure.
4. Connect phone in download mode. Use a USB port that's on your motherboard (the ones on the back of the computer). Use the Samsung USB cable.
How do you connect in download mode?
5. Ensure that Auto-reboot and Re-Partition are both checked. These have a tendency to change after plugging the phone in, so double check them.
Okay.
6. This is where the bootloader will be flashed, along with stock Gingerbread. Hit Start.
Okay but what is a bootloader. Is this Clockwork Mod, CWM?
7. Allow the phone to boot. Okay
8. Close Odin3, and open a fresh one. Select Reorient_Kernel_1.1 in the PDA box.
Okay.
9. Reboot into download mode (adb reboot download, or hold Vol Down + Power).
Did something we did above change the way you get into download mode as this procedure doesn't work for step 4 above.
10. Plug the phone into the computer.
11. MAKE SURE RE-PARTITION IS NOT CHECKED. If it is, you'll soft-brick and have to start over.
12. Flash the kernel (hit start). Allow the phone to reboot.
13. Place the ROM .zip (You know, the one you downloaded from the giant link up there) onto the SD Card.
Internal SD Card or external? Does it need to be renamed to update.zip or anything else?
14. Reboot into Recovery (adb reboot recovery, or Vol Up + Power).
I'm assuming that a menu will come up letting me choose something like "Flash ROM" and then choose the ROM file from the SD card from step 13. ?
15. Flash ROM with CWM.
What is CWM? Is this Clockwork Mod? Is this the new bootloader from step 6?
16. Enjoy!
Will the phone now be rooted along with running Serendipity VII?
If I want to load another ROM later do I just do steps 13-15 after placing another ROM file on the SD card? I'm guessing yes.
Is it possible to go back to my stock Froyo 2.2 if I want? How?
If anyone can answer these questions it would be great. Thanks!
Okay.
Okay.
16. Enjoy!
