How do I power the phone off?
Is there a manual somewhere out there? Mine only came with a book called 'Tips, Hints and Shortcuts.'
I have a mac... is there anyway to sync this to my computer?
Also how do I put files onto the phone... I have mounted the phone onto computer and can see it but I don't know where to put the files.
When using the phone, can you rename folders? How do you manage these folders?
Also is there a way to remove all the crap software that comes loaded.... amazonmp3, no thanks!.... Peep, no thanks!.... I read about "rooting" but this seems complicated, is there maybe an application that does it for you?
Thanks in advance for your time.
I remember the verizon people saying there was a digital one you could get to
