Questions on battery charging - Galaxy 551
Hi all,
1) Anyone know how long would it take for the battery to be fully charged ?
2) Is there a way to check the percentage of the battery status? The status on mine showed "charged" (from charging) but the battery icon on the top is only half-filled (with a + sign) with blue color so I wonder how full the battery is after it is charged??
Since it is the first time I charge the battery, should I leave it to be charged for overnight??
3) How long would the battery last?
Hi all,
1.)Depends on what you are charging with ? Charger or PC
2.)There are battery apps,widgets available .BUT I have customized my ROM (Gloat,Gloat) which shows percentage directly .
NO,dont ever leave it charged overnight.First discharge the battery completely then charge it
3.)3/4 hours if you use full power ,8 hours for heavy normal ,16 hours for normal,36 for light ,48 is super minimal.:)
My phone status changed from "charging" to "charged" in about 2.5 hours (using the charger). But as I said the battery icon on the top is only half-filled with blue color. Then I left it charged for another hour or so and then the battery icon is fully-filled. I guess that must indicate that the battery is fully charged so I disconnected it from the charger. So total took about 3.5 hours.
hi
as an experience, when the charged is appeare, it takes an hour too fully charged, when a notification sound play and on top left appeare a icon with blue battery and 100% on it, now your battrey is fully charged.
مهاجرت کانادا
