Root Questions on Rooting
Taiken84
What is the difference between a temp root and a perm root? I understand temp root is reversible but what is the difference in functionality?
If I temp root and delete or install apps and I reboot will those apps return or be deleted?
What are the perks of perm rooting?
What are ROMs?
Is UI totally customizable either after temp or perm rooting?
What is S=off?
What is ADB?
