i have a couple of questions...
1. in settings->accessory
i check 'audio applications' - connecting earphoneswill enable audio apps
in quick panel.
question - when i connect the earphones, pressing the play button does not start the music. is this normal?
2. quick panel
is the the panel when you pull down the notification? where you see wifi, gps, sound...etc?
question - how do i modify (add/delete) apps from this quick panel?
in quick panel.
2. quick panel
