Quick access to camera from pattern lock screen?
parkschr
Is there a quick way to access the camera from the draw pattern lock screen?
There was one on GB. You just swiped over to the camera.
Unfortunately no. But if you go under security and uncheck the box for lock on power button press or whatever it says, it will delay the lock until the allotted time you choice. This will allow you access to the slide screen longer so you can easily access the camera if you are anticipating taking pictures.
