Apps Quick App Maker Studio L - Free IDE for develop Cross-Platforms Gui databases applications.
appexpert
Hello
Quick App Maker Studio is new multi-platform IDE for creating applications for JVM.
Gui designer suport drag and drop object into Forms.
Supports databases access (SQLite for Now), SQL language, reports, multiforms and other.
IDE contains a set of 60 icons and can be used in develop applications.
Writing code is very simple. The wizard helps you enter your code.
Quick App Maker Studio creates a single file. JAR (JVM).
Jar extension you can easily convert to .EXE or .DMG extensions (jar2exe, Jar bundler...).
Quick app maker studio
-visit site and download your free version of Quick App Maker Studio.
-video instructions are published on the website
Photo gallery-ide screenshot Quick app maker studio
Thanx
