quick question: saving images
hi, i'm deadmanepoxy. i signed up months ago to ask this very question, but forgot about it. hopefully someone can give me insight
say i downloaded an app - this one is a good example: https://play.google.com/store/apps/...idGravureKingdomSample1&feature=search_result
(the app i want the photos from specifically is a paid one, but similar enough)
now, say i want to take those photos from their location in my phone's memory and save them onto my HD.. i have tried finding them on my own in both Commander and Explorer, but have had no luck.. screenshots leave something to be desired.. so i'm curious as to whether this can be done, and if so, how. thanks for any help provided
This is interesting and the answer will be "Where does the app store the photos (internal memory of the phone or on SD card)?
On the SD card look for a folder with a similar name to the app and inside that folder you may find the Pictures in another folder. Only problem is going to be the format they are in. You may not be able to view them with out the app.
If in internal memory they could be anywhere, but a good starting point would be in the /data folder, and again what format they are in, that is, they may not be jpeg or whatever file extension we recognize as image files.
