Quick Switch is a quick widget to change the system settings of your phone just by a simple click on a button in home screen instead changing your settings step by step in menu. If you are using Android OS, which provides users with plenty of features, sometimes you must be annoyed that it is inconvenient to change so many settings by going through menu after menu. I have the same feelings about that, too. So I wander whether there is a widget to achieve quick switch for some frequently used settings. So I searched it in market, I did find some widgets that used to quickly change settings. Quick Switch is such kind of widget.
Frequently used settings may include Wi-Fi, Bluetooth, GPS, Auto-sync, Screen Timeout, Data Connection, Auto-screen Lock, Auto-Rotate Screen, Vibration/Silent Mode, Lock/Unlock Pattern, Reboot (Rooted), 3G-2G Toggle, Speaker Mode. Quick Switch provides users with the above 13 choices to be shown in a bar which shown in your home screen. While the number of the buttons in the bar is limited, namely, you can choose 5?6 or 7 buttons displayed in that bar. Once the selection is done, what you should do is back to your home screen to change your system settings just by a click on the related buttons, which is very handy and easy. One thing to should be kept in mind is that "Data Connection" and "Lock/Unlock Pattern" is not available in droid 2.2 yet, so if you are using droid2.2, you can use the rest 11 items.
It works well until now. It would be better if more settings, like screen "Brightness" setting can be added.
So you can search Quick Switch in the market or visit the following address to take a look at this useful but free widget. Address:
Screenshot:
Screenshot:
