Quick Text in S3
athegn
Android Expert
Been asked if it is possible to have a quick text facility in the S3.
AFAIK the S2 does not have this; I use Handsent so have it there.
Can anyone who has an S3 please tell me if it has this facility and how to access it?
You should be able to do it via the basic text messaging app.
Go into Settings for it > Quick message > enable and set quick messages.
Hope this helps :)
We'd have to do the same as you and search the manual to get the answer. Ctrl+f to find
I was not being lazy. I had already tried searching but could not find an answer.
I guess I am using the wrong search phrase i.e. quick and/or text
