Help Quick way to launch Samsung Kies?
R
rumbataz
Guest
I've started using Kies to transfer files wirelessly between my PC and my Samsung tab. However, it's a bit of a pain to go into the Settings and then Wireless and then activate Kies on the tab.
Is there a quick way to launch Kies on the tab?
If you long press on the screen and then instead of choosing the tab applications or widgets you choose "other" I think you can put a kies short cut from there. I'll double check for you when I get home later, I've not got my tab with me today
