CaptNorris5
So it appears as though quick office isn't supported on the prime. Any idea why or if there is going to be some resolution at some point?
I can verify that Quickoffice Pro HD does install and appears to run just fine on the Prime (latest update, .14). I originally bought mine directly from Quickoffice, so I get my install file directly from them.
Is that version 5.0? I see it now supports Office 2010 files in that version which is what I need badly along with its ability to connect to the shares I use.
Also did you choose TF101 when you purchased the app from their site? I do not see an option for TF201.
