brendanb581
Why is the portrait qwerty so hard to type on?
The iPhone one is so easy compared to this.
I always press the wrong buttons!
Word.Why is the portrait qwerty so hard to type on?
Try this how to guide to install the HTC_IME one (its easy, honest!)
Installing the HTC Keyboard On Your X10 - SE-NSE Forums
Also make sure you have up to date firmware. The standard one got better after the latest updates. I switch between the HTC and the Standard one on the phone depending what mood I'm in (some days I seem to have a very non capacitive index finger - go figure!?)
I am using the HTC keyboard currently. I just don't find it very accurate![]()
Did you install the calibration app for that? With this installed it becomes verry smooth to use. It can be found easily on the XDA forum. Try that before going else were for your typeing needs. If after that it is still unsatisfactory start exparimenting with market keyboard replacements. I myself have found TouchPal. All tho its a china built app it is of a very fine build and quality I have found it to be the perfect replacement.
IThen I reskinned it with the custom HTC keyboard link from from a previous thread so now it looks purrrrdy!
Was that via XDA Gimpsta's site? It's pretty cool. I redid mine having had the same one for a couple of months, just to ring the changes and to blend in with my new wallpaper.
The calibration tool was in Menu>Settings>Locale & Text>HTC_IME Mod settings>Text Input then scroll to bottom.
yeah the gimpsta site is pretty neat.. i saw 1 there from you too suze..
