Help R2BA020 TrackID force close issue
D
Deleted User
Guest
Just recently update my phone to the latest build. Now TrackID force closes every time i try to use it. Is anybody else having this issue. or bet yet a solution?
and yes i have tried re-installing update.
Works fine on mine after update, the only issue I had was Swype Keyboard will not work, other than that everything is good.
Yes, I had the same problem once I updated my X10. I was able to fix it by doing the following:
Go to Settings -> Applications -> Manage Applications
Select the TrackID app
Tap on "Clear data"
Tap on "Force stop"
Now try launching the app again. Worked great for me after I did that. Cheers.
Tap on "Clear data"
Tap on "Force stop"
than you
Mine force closed as well, then wiped the songs on my list. it's working but I'm having other issues now. I find it running much slower since the update, I've notice lag from texts (opening or sending), opening timescape and clicking on tiles, and running games (robo defense)
