R910 my cel is restarted
elpo3ta
i just as I can fix it. pls help me? factory reset it. remove it and use the stock CWM + Odin>>> Who can help me?
This is the intro area here at Android Forums. If I knew your device well and had the answer to your problem... I would gladly lend a hand. I suggest that you should check out the area where the owners of your phone hang out. They know your device well and will be best to assist you. That area can be found by following this link: Samsung Galaxy Indulge - Android Forums I hope the good users of your device can help you solve your problem.
