Root Radio updates won't flash
Meltz014
Member
Hey, so i just flashed Fresh 3.3 and all is fine and dandy, but when i try to flash the new baseband/PRI, nothing happens. I followed the guide on Fresh's site, and everything seemed to go well (flash .zip from sd card > choose .zip > it flashes > reboot > goes through the second flash process > reboot), but under software info, the baseband is still 2.05.00.06.10 and PRI is still 1.40_003. Any tips?
wipe cache, and dalvik cache then flash zip form sdcard restart, wipe cache, dalvik cache, flash other radio zip boot
Okay, great. I did that, and it still won't work. I got the baseband update to 2.15.00.7.28, but the most recent zips still give me nothing. Thanks for the help, by the way
i had the same problem. when you power into your boot loader screen make sure at the top it says s-off.
If it says s-on then it wont load the radio
Yup, that was it. The fix: all I did was flash unrevoked forever, then redo the radio/prl update, and it worked! Thanks for the help guys
