Well this is an Android discussion site, so not the obvious place to ask about iPhones
However, if shutting it down and restarting doesn't fix it (which I assume it doesn't) I suspect hardware damage, in which case repair will be your only option. Connect it to your computer and back it up, then talk to Apple. The only other thing I can think of is a hard reset (however you do that on an iPhone), which may be worth a try (but back up first), but my guess is that it will require a repair.
