Accessories RAM Mount brand car mount for Incredible in a case
cpirner
I have a Droid Incredible cased in the black high-gloss silicon case from Verizon. I have the extra capacity battery so I have the typical cut out in the back for the hump back battery cover. (This makes it pretty much the same thickness as phone with the same cover on a phone with a standard battery)
None of the car count systems designed for the Incredible will work because of the case. Most of the universal systems I have investigated block or press the volume or power keys and usually block the USB or headphone port.
Here is a universal cradle that can be adjusted to maintain access to all ports and buttons and that holds my cased Incredible very securely:
Part Details
There are a number of mounting options but here is the particular one that I am using:
Part Details
Here are a few pictures of it installed:
P.S. I am not affiliated with Ram Mounts in any way. I'm just sharing some info about something that works for me and that you might find useful.
RAM Mounts makes some good stuff. I've used their products on 3 of my motorcycles for mounting GPS's. I'll have to look into this and see about using this as my GPS and to drive the stereo!
