Root Random reboots during call
BigBossman
Ever since I had my phone this has happened and now I am have Mobster Rom HD (with Anthrax Kernel and 3D fix) and I still have this problem. Occasionally when I am talking the phone makes a glitchy sound from its earpiece and reboots. I did try going back to a nandroid back up and I reflashed the ROM but this still happens. Any help?
buttered toast is an updated anthrax minus a few of chad's personal additions. IMHO there is nothing in anthrax to make it any better than BT or MAC, and its outdated
So between Mac and BT what's your opinion and if I can get a link to both that'd be great. (Perhaps flashing one may fix the issue I'm having)
Cool so far no complaints I'll let you know if I still have the calling issue (over clocked to 1512 on the ondemand governor and the battery life is decent) how's your battery life?
Xondemand can give better battery life since it's in deep sleep mode when the screen is off. ;)
Technically any governor can "go" into deep sleep mode, since deep sleep isn't governor or io related. The only thing that stops deep sleep mode, is partial wake locks; which keep the phone awake. Do some research on it, since this is generally crucial to your battery life. The only app you will need is better battery stats from the play store.
Thank you both but xondemand isn't available when I try to change the governor in ROM Toolbox but is there a way around this?
Well here's the situation I installed Kernel Tuner and it said CPU1 is offline and that was with both BT and MAC. So that means there is no Dual Core? Also xondemand was available on BT but not MAC so what do I do?
I activated CPU1 in Kernel tuner while on BT and it seems to stay on but everytime I go into CPU Tweaks it turns it off. BTW is there a way to add xondemand on MAC?
The reason it turns off is because it automatically shuts off when not needed to save power, and turns back on when needed.
I enjoy the lagfree governor as well. Its great for performance, and battery life. For me, anyway.
Your mileage may vary ;)
I'm gonna try lagfree on MAC because I think anthrax was the reason for the reboots. (And I assume since BT uses the same "framework" it'll do the same."
Edit-So lagfree seems to be running quite nice but is there a way to add any governor to a kernel?
