rapid battery drain on my HTC One V
dr4sight
My HTC One V has been showing considerable battery drain the past few days.
As an example I awoke yesterday at 7am, the battery was at 100% charge and remained on the home wi-fi until I left for work at 9:30. I did not use the phone at all during that time. Got to work at 10am and checked. Battery was down to 68% (work has no wifi available). By 10pm and using the phone very little the charge was below 10%.
I installed Battery Doctor and it suggested that the main culprit could be Google Play Services and research tells me it has been a recent issue for some. But supposedly an update to it has slowed battery drain.
Problem there is I don't see Google Play Services when I go to the Play Store and look at the list of My Apps installed-or-all.
I just re-installed Juice Defender this morning (had it on my prior Android phone) and hope it might help.
Can anyone suggest ways to halt this rapid draining of the battery?
Google Play Services isn't an app, it's part of Android (more or less - purists, don't jump on me for this).
Look at your battery drain and see what's draining the battery. Android has that in Settings.
