I would be curious to know the answer to this. My guess is that it's impossible because the blades are proprietary and have patents.How impossible is it to switch out razor blades? A while back I ended up with some expensive "cartridges", only to find that they won't go on the handle. I'm pretty sure that they're the same brand. Is there a trick to making them fit?
I'm pretty sure it's at least partly Gillette. Is there maybe a way to glue them together, or maybe use magnets? Whatever happened to the OLD razors that could be resharpened? Those would probably be environmentally better, as well.
My grandfather was a barber. He gave me my first shave with a straight razor. I was old enough to remember the occasion but young enough that I was not in need of a shave. There he said. You can tell everyone that your grandfather gave you your first shave.
So there you go. It started a fascination for the tool so I lobbied for and inherited most all of my ancestor's straight razors. They are all stored neatly in an old cigar box ready for my son to inherit.
I've never attempted to shave with a straight razor. I used a safety razor for decades. I finally broke down and invested in a quality electric razor. The shave is sub par but it's a far easier / handier means to shave. Somehow I escaped the multi blade - handle specific razors as well as the disposable ones.
I have no clue but it sounds reasonable enough. I spent a lot of my summers as a kid in my grandfather's shop and witnessed many shaves. It was quite a process that had to be enjoyable to the customer. I doubt you could get a shave these days. Or a good shine for that matter.I heard something about barber apprenticeships, not sure if true or not though, in that they have to lather up a balloon, and try and shave the lather off with a straight razor without the balloon popping. And they must do this before been allowed to shave a real face.
You could possibly glue them, but you'll only get to use one of them that way and then need a new handle.I'm pretty sure it's at least partly Gillette. Is there maybe a way to glue them together, or maybe use magnets? Whatever happened to the OLD razors that could be resharpened? Those would probably be environmentally better, as well.
I hate the word too. That's why I rarely miss the chance to point out that it means dumping their mess and costs on other people.I really hate that word "externalities". It's been around since the '60s, I guess, in economics. Finally some are admittimg that these are really "internalities", or to summarize an important idea from Cleveland Amory's Save the Earth: "in the air, on the land, in the water, nowhere is 'away'", and thanks also to Adbusters, the journal of the mental environment, publisher Kalle Lasn, in Canada.
