I can receive pics , but every time i try to send one it asks to resize, I say OK,
and then another message appears. "Message size limit reached"
sorry you cannot add this pic to your message... WHY....![]()
No idea, I get the same resize message, I say ok, and it sends no issues
Are you using the stock message app? I've used the stock and and Go SMS and haven't had any problems sending. It gives me a message that the picture is too big but then compresses it and sends it. With Go SMS I have my MMS size set at 1.2mb, I'm on verizon as well. If it works for me, it should work for the OP.
Try Go SMS and Handsent. I've had good luck with both.
