Razr m
  • Start date Start date
A
Android Question
Guest
My razr m will not charge. When it's charging in the wall it has a green light and the when it gets to 5 percent it turns on. When it turns on it says to connect my charger but it already is plugged in and then it will shut down when it gets to 3 percent. It just keeps doing this over and over again. Can anyone please help.
Might be the battery .. Is it removable and do you know anyone else with a Razr who could let you try their battery?
Otherwise, I'm guessing you're looking at a repair (hopefully under warranty), I'm afraid :(
