Help RAZR Vibration problems
pj221
I've been noticing an issue with the vibration on my RAZR. Sometimes the haptic feedback on the multitouch keyboard and the soft keys is very weak, it almost feels like vibration isn't even on while I'm typing. Other times, the vibration is fine. Is anyone else having this problem or know a fix?
I'm having this problem as well. Hasn't really bugged me since I usually turn haptic feedback off. Still, I did a quick Google when it first happened, and some people have experienced it on other Droid phones, sometime fixed with software updates.
Try this, go into your bathroom or something.. Try haptic feedback with the lights on, then flip them off. I noticed that the haptic feedback is stronger/weaker in different light.. Kinda weird.
Wow, I tried it and it worked. I wonder if this intentional, and if it is, why? I really hope MOTO recognizes this and fixes it. It is small problems like these that really annoy me to the point where I want to return the phone...
Wow, you are exactly right. I thought I was just crazy with the feedback being different sometimes, but your theory is right... I hope that is changed.
I hope its a bug, but it seems like something that could be by design(I cant think of a reason why)..
Mine does this as well... doesnt seem to make a difference with lighting conditions as it will come and go sometimes within sending the same text message.
It also randomly stops vibrating for my alerts. have to restart it to get it to vibrate again, and then it may work for a few minutes then stops again
Sounds like you have something else going on. Might want to exchange it.
