Help Razr Won't Get on Wi-Fi Anymore?
radjxf
I jsut picked up a Razr 2 days ago.
Set up my home and work networks. Everything worked fine for 2 days.
Now I'm at home and it usually knows to get on our Wi-Fi.
Our network is listed under the wifi networks, but it's stuck in a constant loop of Scanning, Connecting, Disconnecting over and over.
I rebooted the device, but an clueless why this is happening now.
Any help for this newbie (first ever smartphone) would be much appreciated.
Once in wifi settings, go to menu then manage networks. Try long pressing on your network and choose "forget". Then choose it again from list of available networks again.
Sorry, actually once in wifi settings scroll all the way down to manage networks, then forget network, then re connect
This POS is doing this again! I followed the above advice and rebooted 4x, still won't get on my wifi.
I wonder if this has anything to do with the 'sim card authorization' issue we all experienced in the last 2 days?
What does WiFi have to do with Sim Cards?
MAybe make sure your router is fine before you discard the phone?
I've been having a problem with my wifi for the last few days as well. Usually a restart will fix it for a while though.
Just curious if the two events were somehow related to each other.
The router is fine. Everything else here works on Wifi, just not my phone.
Now I get to hear for the 10th time from the wife: "should've got the iPhone".:rolleyes:
