I have removed the rcp program but the ringtones are still on the phone, I don't know if they are on the sd card or internal memory.....need some help....
Use Astro to search for the folder where they are stored (will only work if they're saved to SD). If they're saved to internal memory then you will have to hard reset your phone back to factory settings to remove them (people have had this problem using sites like myxer).
