This is with a Samsung Galaxy 2-10.1 GT-P5113. I was told to do the following to turn off the on screen keyboard so I could use my Bluetooth keyboard.
It is simple to remove on-screen keyboard when you have Bluetooth keyboard.
To remove on-screen keyboard, follow 5 simple steps.
Go to "Settings"
Select "Language and Input"
Select "Default Samsung keyboard" under "Keyboards and input methods" section
Turn off "Use on-screen keyboard"
push "Setup input methods" button
There is no turn off "Use on-screen keyboard"
I did find online the following bellow.
But I found an other way online. That with a rooted tablet I could go into the system > app dir and copy the following 2 files to my SD card "SamsungIME.app" and "SamsungIME.odex". Then del the 2 files in the system > app dir. Then I would not be bothered by the on screen keyboard and I could use my Bluetooth keyboard. That part worked like a charm. Then the charging port on the Bluetooth keyboard got cracked and I can't charge the keyboard anymore. So I went to were I had stored the 2 files for the on screen keyboard on my SD card and copied the 2 files back to the system > app dir then restarted the tablet. the on screen keyboard is not coming upon request (like tryng to send a sms). The rest of the tablet is fine. I borrowed an other bluethooth keyboard and the tablet is still stuck, connected to and using the bluetooth keyboard. How do I fix this?
Steve
Go to "Settings"
Steve
