OK, solved, maybe I should try reading the instructions! PhilHi, I have started the re-flashing process, the phone has been showing "Downloading" for about 45 mins, is this normal or am I being impatient? Phil
Hi, this is the firmware I was flashing, my phone is unbranded and sim free, it wont go into recovery mode. PhilDid you flash the right firmware for UK mate? Will it go into recovery mode (power, home, vol up)?
How do you wipe the device? PhilActually doing the same thing .. The initial reboot can take a while. However, did you wipe the device before flashing ?
If you didn't you would basically "upgrading" your device, which obviously won't work as you go backwards.
If you use a custom recovery like Philz, you can actually wipe the phone for new ROM installs. That gets rid of all the old stuff.
Hi funklogik, managed to get it into download mode, but as suggested how do you wipe the phone prior to installing the older firmware? PhilIm tryin to find some advice for you mate. Keep tryin to get it in recovery or download mode.....
Hi, thanks for your help, will give it another go tomorrow, have had enough for today!! Getting p##sed off now. Philphew! It isnt a brick thencan you get into recovery? You can factory reset from there then try booting. Youre gona lose all your data though
I dont think he's rooted or anything bro. Was my advice bad? Havent heard of a phone being hard bricked by flashin stock firmware before. I suppose i should have suggested a reset since he's downgrading![]()
Hope its ok man. Worst case, its still under warranty :thumbup:
Hi All, I have finally managed to get the firmware installed, I had to do a factory reset, then install the o2 branded firmware, then upgrade to the unbranded firmware, it was the only way it let me install the unbranded firmware. Thanks again for all your help. Phil
