Tennaki
Member
If you find yourself struggling to use your device with one hand because of the large screen (because puny hands :c), take a look at the app Niwatori from the Play Store. It will bring the top half of the screen downwards so you can reach it easily without having to adjust your phone to a comfortable position. It does require Xposed.
https://play.google.com/store/apps/details?id=jp.tkgktyk.xposed.niwatori&hl=en
You can assign a shortcut the app creates to your Home button using GravityBox's navigation keys actions section. I assigned holding the Home button to bring the screen down, give it a shot; it works greatly.
