Hi All,
(I've read tons of Threads here, but not yet found a solution).
My Galaxy Tab 10.1 is useless right now as it cannot write to internal storage.
Lots of apps crashing on use and doing a factory reset from the recovery menu does not help (Tablet is in exact same state aon reboot).
So, I've been using adb:
However, when I try to write via Odin, I get an error message on the tablet in Red:
Cheers,
Ro
Here's the mount information from shellC:\Program Files (x86)\Android\android-sdk\platform-tools>adb remount
remount failed: Operation not permitted
So, I've tried to mount manually from adb shell:shell@android:/mnt/asec $ mount
mount
rootfs / rootfs ro,relatime 0 0
tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
/dev/block/mmcblk0p4 /system ext4 ro,relatime,barrier=1,data=ordered 0 0
/dev/block/mmcblk0p5 /cache ext4 rw,nosuid,nodev,noatime,barrier=1,data=ordered 0 0
/dev/block/mmcblk0p8 /data ext4 ro,nosuid,nodev,noatime,barrier=1,data=ordered,noauto_da_alloc,discard 0 0
/dev/block/mmcblk0p1 /efs ext4 rw,nosuid,nodev,noatime,barrier=1,data=ordered 0 0
/dev/fuse /mnt/sdcard fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=1023,default_permissions,allow_other 0 0
But, I have no SU command:shell@android:/ $ mount -o rw,remount -t yaffs2 /dev/block/mtdblock3 /system
mount: Operation not permitted
shell@android:/ $
shell@android:/ $ mount -o remount,rw -t rfs /dev/block/stl9 /system
I've got the su binary from downloading off aforum, but I cannot copy that up either (even to seemingly writable mount points)shell@android:/ $ su
su
/system/bin/sh: su: not found
So then I followed a guide I found linked on a forum to get the Tablet Restocked to factory settings.C:\Program Files (x86)\Android\android-sdk\platform-tools>adb push su /cache
failed to copy 'su' to '/cache/su': Permission denied
Is my tablet bricked ?Bct_sync_Odin: Error to NvBuBctUpdate![err:0x140005]
DownloadPartition_Odin: Error to Bct_sync_Odin![err:0x140005]
Tegra_Nand_Write: Error to DownloadPartition![err:0x140005]
Cheers,
Ro
