Help Reader and Kobo Reader
ral
Android Expert
The HTC Desire has a pre-installed reader app with several free Kobo ebooks. I wanted to download two of the free classics, but when I click "Free Classics" on the Reader, nothing shows up.
I thought I have to upgrade the program so I downloaded the Kobo Reader from the market. From the Kobo reader I was able to download and install the two free classics I wanted.
But the two readers seems separate. What I downloaded in the Kobo reader does not show up in the default Reader. Is there a way to integrate the two?
I don't think so.
But there is a way to import .ePub from your SD card in the DHD stock Reader:
With the DHD stock eBook reader to import an eBook on your SD card you have to create a folder 'Digital Editions' on the root of your SD card.
In this folder put your .epub (sometimes people have to use USB-PC connection, I did it with my file manager).
The book appears in the bookshelf of the reader :)
And the DHD stock eBook reader can lookup a word/sentence directly in a dictionary!
For lookup in a dictionary, I mark the word/sentence in the eBook and then I can choose Google dictionary, Wikipedia, Google etc.
Harry
  • Like
Reactions: ral
I am confused by this step
More help please :)
"In this folder put your .epub ..." means:
Copy your .epub files in the folder 'Digital Editions'.
Before, you have to create the folder 'Digital Editions' on the root of your SD card.
I used my Android file manager :)
EDIT: Note, the folder 'Digital Editions' is for the stock DHD eBook reader, not for the Kobo.
Harry
