readers hub
liebau
Question on Readers Hub (on Galaxy 2)
Is it possible to read an ebook I have downloaded on Readers Hub if I am off line?
That is with the data switched off.
I dowloaded a trial book and i could access it ok while I was on line but as soon as I switch data off i cant even login to Reader Hub anymore.
Is it possible to access a book I have already downloaded if, for example, I am travelling and not in range or don't want to use expensive data from an overseas carrier.
if the answer is yes, how do i do this?
Hi Liebau and welcome to Android Forums!
That's a good question. One that I would ask in the appropriate S2 forum. Go here:
Android Phones - Android Forums
And scroll down to the Galaxy S2 forum that applies to your device. They are listed by provider. You can feel free to copy your post in there, or better yet: we can move it there for you. Just let us know where you what it, and we will move it.
It's great to have you here :)
thanks for reply,
my phone is Galaxy II model GT-I9100
Android version 4.0.4
please move my question to the appropriate formu, but I woud epect Readers Hub is a software issue not a hardware issue.
Alternatively, is there an open source e-reader available for Android that will run off-line?
Thanks
Bruce
