A Android Question Guest Sep 14, 2015 #1 Is there a way to get stock android in edge plus? I moving to android and would like a clean android, the way google ment it to be.
El Presidente Beware The Milky Pirate! VIP Member Sep 14, 2015 #3 MLSS said: You could use Google's launcher or try Nova launcher. Click to expand... Samsung also offered an AOSP theme on the S6/S6 Edge so presumably it will be available on the Edge too. This, along with MLSS' suggestion above will give you the best "clean" experience if you're not willing to root.
ThorPrestby Lurker Sep 14, 2015 #4 Hi ! Im willing to root (if there are any good guides out there). Is the stock android clean google version better than regual s6 with theme and launcher?
