Ruben
Android Expert
Have you ever picked up your wonderful device and heard it squeak? And even in normal handle I'm sure you've heard this happen. Well, if you look close enough it only happens on the right lower side when you press in.
On the left side there is a hinge that the cover connects into, while on the right side there is the microSD slot. This is where the plastic presses in as there is not a hinge keeping it tight.
Fix ideas anyone? Any way to fill up the SD space?
