Help reboot and browser issues
stephen C
When browsing my stock browser stops responding every 2 minutes or so....also my prime reboots itself 10 + times a day during use. Issue started when I downloaded the ICS update please help, P.S. I already hard reset it, did not fix also I dont want to download an alternate browser I just want the stock one to work.
This has been admitted by Asus and they are working on a solution. Here is an XDA thread on this topic:
Official ASUS Thread - Random Lockups after ICS update - xda-developers
Good Day,
For those users who are suffering from the "Random Lockup or Screen Corruption" problem after the ICS update we are currently finalizing our replication efforts along with a final fix. We have identified two issues that could potentially cause this problem and will start contacting a subset of users who have already reported the problem for further testing and system level information.
Issue -
1. System might randomly lockup or generate a blind screen effect after the ICS update. I have received a few reported cases matching this behavior and we will be in contact with most of you in the near future.
a. If we do not contact you directly, it does not mean we are not working on this problem. I have read all the messages and randomly selected a couple of users for further contact. We will have a fix for this problem shortly.
Sincerely,
Gary
1/18/12 Update - We will continue to contact additional users over the next two days. We are in the process of qualifying a fix now and are awaiting a system return to verify this fix with our partners shortly.
1/19/12 Update - The ICS 9.4.2.11 update being rolled out now addresses the horizontal line and random signal line issues after the initial ICS load. It also addresses poor video playback (especially YouTube), however if you still have the YouTube corruption problem after this update, please uninstall then reinstall Flash from the app market. This patch also addresses the random reboot problem after the ICS update but we still have another patch that is in qualification testing at NVIDIA to fully solve these problems.
1/22/12 Update - I will provide an update tomorrow on our new Customer Service Support program for the Transformer Prime and additional forum support that will be coming in the very near future. In addition, I expect an update from engineering and NVIDIA shortly on the random lockup problem after the ICS update.
1/23/12 Update - Replication testing is still in process and I do not have an update to provide yet. We will provide a customer support hotline and direct email address shortly for users suffering with this problem. In the meantime, we will start another series of direct communication between our service/engineering group and selected users for additional testing.
1/25/12 Update - We are working on two different solutions now and hope to have a fix available in early February. One option to try is to revert back to the last Honeycomb image through the manual update process, set the unit power mode to balanced performance and screen brightness manually to 50%, and then manually update to the latest ICS build using these instructions - ASUS Service for North America. You will need a fully charged battery and have the system plugged into AC power. This worked on a couple of returned units but not on all units. Only try this procedure if you are comfortable with flashing a new ROM image and want to take the time to complete each process.
1/31/12 Update - We are now testing a firmware and driver update. I will provide an update once initial alpha testing is completed.
2/1/12 Update - We received new code from NVIDIA today and are in the process of testing it. If this code is acceptable and provides a solution to the lock/reboot problem after the ICS update, we will release it in beta form for additional testing with users suffering from this problem before implementing it in the next OTA update. I should have an answer in two days if we can release the current patch code.
Just a reminder, for those I or engineering did not contact directly yet about this problem, it does not mean we are ignoring your problem. We have read all the messages so please do not be upset if we have not contacted you yet.
__________________
ASUS Technical Marketing Manager
Follow us at usa.asus.com and ASUS North America | Facebook
I am traveling to Taiwan from January 27th through February 4th to work on Transformer Prime problems with our engineering group. I will read messages and forward information to R&D but expect direct replies to be very delayed or answered by Customer Care.
Got my Prime today and was thoroughly impressed. Downloaded and installed the ICS update with no problems. Now have screen blinds effect - still responds but cant see alternate 5mm strips. Only full off then on restores normal play - please help
I purchased my Transformer Prime last Friday and immediately updated to ICS. Since then, it's locked up on me and rebooted three times. It's irritating but definitely not a deal breaker, I'm really enjoying this tablet. It is reassuring that ASUS and its partners are working to roll out fixes.
My main issue is in Youtube, when you do a search, the touch keyboard pops up and flickers for a while then turns solid and you can type. Two of my three reboots have occured while in the Youtube app. I re-installed Flash but it has not solved the problem.
Can't agree that 'it's reassuring'. where else would you agree to buy something in the hope that sometime it will work. Asus should make sure their cutting edge devices work before they release them. If they want to use me to test and develope devices don't expect me to buy them!
I know you said you weren't interested in using an alternative browser but I have been using dolphin hd browser and have zero issues, also you can set the mode to desktop which is great when using this tablet.
I would say this is better than having flickering.
True, and you're issues are much more severe than mine. I hope you get them resolved, or your money back.
