Hard to say what happened, I'Ve flashed 4 phones with my ROM as of now and they all seem to work fine... Which recovery did you use? Did you back everything up before flashing through this recovery?
If you did back everything up, try clearing dalvik cache and cache from the recovery menu, might help in fixing bootloop... I know I posted a ROM for about 1 minute on release which had issues, but those were fixed.
If clearing dalvik cache still doesn't work, go to recovery and do a factory reset. It'll delete all your apps and settings though, so back up first! Bootloops are usually caused by user data or dalvik from experience. OR a bad ROM, but I know mine works.
