Root reboot to recovery help
fir3dp
hey..
new here and im from singapore :D
i just rooted my milestone xt with the one click rooting thing. lol
i also downloaded rom manager and did flash clockworkmod recovery.
the problem im having is that im unable to reboot it in recovery. It appears to be loading to recovery screen and then half way an exclaimation mark came out and it just restarted back.
anyone have any ideas?
its on 2.1
thanks guys
You don't say how you're doing it now, so I don't now what "other" means in this context.
However you could always install Quick Boot from the market if that's not what you're already using. I doubt it will help though, when you "did flash clockworkmod recovery" (whatever that means) it sounds like you broke something.
