Help Recast has stopped error
thahim
Since few hours my phone hangs every 5 mins and aftrr a lag
I get this error unfortunately recast has stopped
Any one else faced this?
Any solution and wonder why is this happening?
Hello thahim. It sounds like an app/widget is freewheeling in the background, draining resources to a critical point.
I'd first clear data and cache on the most likely offending app, then reboot the device. If no joy, uninstall the same app and reboot again for the remedy. No remedy still?
I'd next to a hunt for recently installed apps/widgets and do the same one at a time with one and all.
Factory data reset may be next. ;)
Thanks i found that app and uninstalled it :)
Wonder how can galaxy s3 be low om resources?
