Receipt scanner and organizer?
ktchong
What are some good apps to scan and organize receipts? Preferably apps that can capture and interpret numbers on receipts, and automatically enter the numbers into the correct fields.
I tried one quite some time ago named Lemon Wallet. I was very impressed, but although it worked very well. My devotion to its use was lacking. It is a free app. The name is linked.
BigRedGonzo
Expensify is something very specified to your needs. You may want to look at Toshl as well.
Does it do automatically now? I used it a while ago and had to enter everything manually. I gave up. It was too time consuming.
Honestly, I would love something like Neat Receipts but they are not at all a reliable company so staying away from them and looking for an alternative. Something similar for android will be a quite a long shot.
If your trying to organize the receipts for budgeting purposes, why not use a budgeting app that you can customize to your needs. (You will just have to enter these things in manually.) I use "CamScanner Pro" to scan important receipts and use "MoneyWise Pro" as my budgeting app that I enter all receipt info. into. Works really well.
I downloaded and tried Expensify, and found out it charges TWENTY CENTS PER RECEIPT/SCAN after the first ten free scans.
Let me repeat : that's TWENTY CENTS PER SCAN. Every time you use the app to scan a receipt, you incur twenty cents in expense. If you do not like the result of the first scan and rescan the same receipt again, that's forty cents.
I did not even bother trying any of the first ten free scans. I uninstalled the app so fast.
Expensify... aptly named.
Just curious if anyone has any update to report.
I am STILL looking for such app. With the long receipts we have in the US, its difficult to scan even on a flatbed scanner. Cam scanners have never worked with me so I tend to stay away from them.
