pbf98
Android Expert
Ok so I had my issues with ICS and JB seemed to take care of those, but now I have been noticing a new problem that I had not experienced with ICS. I noticed it shortly after upgrading to JB, and wanted to see if it was consistent or just a problem that wouldn't happen again..
The problem is.. I will send a message and the green arrow will not go away (meaning message is still sending) BUT someone will reply to it even though my phone still says that it is sending.. Then After I get use to thinking it sends I will just ignore the sign saying its still sending and then someone will tell me that I didn't answer them.. so then I will copy the message resend it, and then they immediately get two messages of the same.
This issue is really annoying and was curious if anyone else has noticed it recently. Or if anyone has any suggestions.. Thanks for your input!
