Record Retrieval Problem
  • Start date Start date
A
Android Question
Guest
Let COnsider this logcat
01-13 15:24:11.634: E/AndroidRuntime(3781): FATAL EXCEPTION: main
01-13 15:24:11.634: E/AndroidRuntime(3781): java.lang.NullPointerException
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.widget.Toast.<init>(Toast.java:92)
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.widget.Toast.makeText(Toast.java:238)
01-13 15:24:11.634: E/AndroidRuntime(3781): at com.ProgramingTutorials.sqlite.Database.getCandidate(Database.java:96)
01-13 15:24:11.634: E/AndroidRuntime(3781): at com.ProgramingTutorials.sqlite.ViewCandidate$1.onClick(ViewCandidate.java:48)
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.view.View.performClick(View.java:4091)
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.view.View$PerformClick.run(View.java:17072)
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.os.Handler.handleCallback(Handler.java:615)
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.os.Handler.dispatchMessage(Handler.java:92)
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.os.Looper.loop(Looper.java:153)
01-13 15:24:11.634: E/AndroidRuntime(3781): at android.app.ActivityThread.main(ActivityThread.java:5086)
01-13 15:24:11.634: E/AndroidRuntime(3781): at java.lang.reflect.Method.invokeNative(Native Method)
01-13 15:24:11.634: E/AndroidRuntime(3781): at java.lang.reflect.Method.invoke(Method.java:511)
01-13 15:24:11.634: E/AndroidRuntime(3781): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:821)
01-13 15:24:11.634: E/AndroidRuntime(3781): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:584)
01-13 15:24:11.634: E/AndroidRuntime(3781): at dalvik.system.NativeStart.main(Native Method)
Here is the Another class who control SQLite
package com.ProgramingTutorials.sqlite;
import android.annotation.SuppressLint;
import android.content.ContentValues;
import android.content.Context;
import android.database.Cursor;
import android.database.DatabaseErrorHandler;
import android.database.SQLException;
import android.database.sqlite.SQLiteDatabase;
import android.database.sqlite.SQLiteDatabase.CursorFactory;
import android.database.sqlite.SQLiteOpenHelper;
import android.util.Log;
import android.widget.Toast;
public class Database extends SQLiteOpenHelper {
private static final String KEY_ID="id";
private static final String KEY_NAME="name";
private static final String KEY_ADDRESS="address";
private static final String TABLE_NAME="Candidate";
private static final String DATABASE_NAME="odesk";
private SQLiteDatabase db;
Context context;
public Database(Context context) {
super(context, DATABASE_NAME, null, 1);
this.context=context;
public void close(){
db.close();
public boolean addCandidate(Candidate c) {
db=this.getWritableDatabase();
try{
ContentValues value=new ContentValues();
value.put(KEY_ID, c.getId());
value.put(KEY_NAME, c.getName());
value.put(KEY_ADDRESS, c.getAddress());
if(db.insert(TABLE_NAME, null, value)!=-1){
Log.d("Insert", "Data Inserted");
Toast.makeText(context, "Data is Inserted", Toast.LENGTH_SHORT).show();
return true;
else{
return false;
catch(Exception e){
Toast.makeText(context, e.getMessage(), Toast.LENGTH_SHORT).show();
return false;
//Get the record of Candidate from SQLITE
public Candidate getCandidate(int i){
try{
db=this.getReadableDatabase();
String sql="select * from Candidate where id='"+i+"' ";
//Cursor cursor=db.rawQuery(sql, null);
Cursor cursor=db.query(TABLE_NAME, new String[]{KEY_ID,KEY_NAME,KEY_ADDRESS}, KEY_ID+ "=" +i, null, null, null, null);
Candidate c;
if(cursor!=null){
cursor.moveToFirst();
c=new Candidate();
c.setId(cursor.getInt(0));
c.setName(cursor.getString(1));
c.setAddress(cursor.getString(2));
db.close();
return c;
else{
db.close();
return null;
}catch(Exception e){
return null;
@Override
public void onCreate(SQLiteDatabase db) {
db.execSQL("create table Candidate (id int primary key,name varchar(255),address varchar(255))");
Log.d("CREATED", "DATABASE Created");
@Override
public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
here is the Candidate CClass
Context context;
db.close();
try{
return true;
else{
return false;
catch(Exception e){
return false;
try{
Candidate c;
if(cursor!=null){
c=new Candidate();
db.close();
return c;
else{
db.close();
return null;
return null;
@Override
@Override
Here is the ViewCandidate activityclass for get the record
import android.app.Activity;
import android.os.Bundle;
import android.provider.ContactsContract.Data;
import android.view.Menu;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
public class ViewCandidate extends Activity {
Button searchButton;
TextView idTextView;
TextView nameTextView;
TextView addressTextView;
EditText candidateEditText;
Database db=new Database(getBaseContext());
@Override
setContentView(R.layout.activity_view_candidate);
this.searchButton=(Button) findViewById(R.id.buttonSearchByName);
this.candidateEditText=(EditText) findViewById(R.id.editTextSearchByName);
this.idTextView=(TextView) findViewById(R.id.editTextID);
this.nameTextView=(TextView) findViewById(R.id.textViewCandidateName);
this.addressTextView=(TextView) findViewById(R.id.textViewAddress);
this.searchButton.setOnClickListener(new OnClickListener() {
@Override
public void onClick(View v) {
String val=candidateEditText.getText().toString();
int id=Integer.parseInt(val);
Candidate c=db.getCandidate(id);
Toast.makeText(getApplicationContext(), val, Toast.LENGTH_SHORT).show();
if(c!=null){
idTextView.setText(""+c.getId());
nameTextView.setText(""+c.getName());
addressTextView.setText(""+c.getAddress());}
@Override
public boolean onCreateOptionsMenu(Menu menu) {
getMenuInflater().inflate(R.menu.view_candidate, menu);
return true;
Kindly Suggest me what is the problem...
Whenever I try get the record from database the my application has closed...
