Help recover deleted photo for note 4 android 4.4
A
Android Question
Guest
Please advise how to recover photo store in the phone as I can't find the DCIM folder (or even whole note 4 folder/drive) when using recovery program. Thanks a lot !
The default location is /DCIM in phone's internal storage (may be identified as /sdcard/DCIM or /emulated/o/DCIM). This is different from external SD, which would be /extsdcard/...). If it's missing, then try Dr.Fone for Android, as suggested. If you go the Dr.Fone route, minimize app usage, as recovery programs have the greatest chance of success if the storage area has not been written to (possibly overwriting the files you are trying to recover).
Be aware that Dr.Fone is not free, but the analysis report to determine if it can help is. Before buying, check online for discount codes - they are commonly available and can save you up to 50%. GL!
And the Dr.Fone has a trial version, it can scan the lost files but can't recover before you purchase, so do try first to make sure whether your lost photos can be found and decide later.
Did u have Google+ Photo backup turned on my chance? Check your google photo app.
I have mine set to standard storage, which is unlimited backup storage
