rapidsandroid
I am unable to find where the apps I Disabled are located at to re-Enable. I disabled some apps like Media Hub by going into Settings, Application Manager, All, the app (Media Hub), then clicked Disable. The app then disappeared.
How do I enable the same app (Media Hub) later when I want to use it? or is Disable = to delete?
I asked the rep at Verizon & he was unable to find the disabled apps. We think it is an ICS issue because he was able to do the same on his Razr & couldn't find the disabled app after doing so. Information request was put into their Samsung rep.
Suggestions? thanks
PS- For clarification, I am not referring to hiding an app.
Suggestions? thanks
.Think of the members on this site as your unpaid Verizon customer service department. :call2:
