draugmordin
I'm not sure the model of the tablet. It looks like an Eken w70 (camera is on the upper right side), w70_V12 2012.09.20 is printed on the PCB. I see a WM8850 soc, one hynix h27ubg8t2ctr flash nand, 2 x 256mb ddr3, and VIA VT1603A.
The device powers on and shows the "ICS"ified android logo(only the first frame of the animation), OS and kernel and build versions and the "Boot into recovery mode..." message in red on the upper left side of the screen. It stays like this until the battery drains out or reset button is pressed
If I try the Vol+_Power combination I get:
Are you sure system recovery?
Only power button long press again in 10 seconds
Recovery confirmed
Boot into system recovery mode...
Then the Android with the polyhedron animation starts (not stuck this one), a blank screen, and again the ICS stuck animation screen with OS, kernel and build numbers.
I tried also powering it on with a firmware microSD card and with an empty one. Always the same, it won't go beyond the ICS animation.
Can you suggest something to unbrick this tablet?
Recovery confirmed
