Root Recovery error (masterminds recovery)
RD07
Guyes i am facing this problem since i last installed the ICS v3 or like something given by sagar.!!
Actually the problem is that the recovery is giving me error while doing backup of current rom..
everything else is fantastic apart from the sd-ext part..
so the problem stats this..
-when the recovery comes down to the backup of sd-ext the backup starts and some of the files on sd-ext are seem to be backuped ..
but at some point while backing up sd-ext the recovery stops and displays following :-
Backing up sd-ext...
Error while making a backup imag
e of /sd-ext!
plz help me guyes specially @mastermind plz look into this issue,!!
i also flashed blue terror v1.1 base pack with nothing linked to sd-ext but still the recovery is giving same error.!!
plz help me guyes.!! i am stuck..
edit:-
-also it is not generating md5 sums.... plz help
-aso it is again and again saying
Back menu button disabled.
Back menu button enabled.
should i reflash the recovery by sp flash tool..??
e of /sd-ext!
edit:-
Its cos the scripts what are provided by sagar which enables data2ext or app3ext on sdcard conflict with d scripts on ur phone so remove all scripts from sdcard n den do a backup it ll work den or else mastermind needs to provide a MODDED recovery with d necessary changes which can perform backup with the data2ext or app2ext enabled so try first removing the scripts folder from u sdcard if u r not on sagar's rom else u need 2 delete d scripts from phone if u r on sagar's roms
i am currently on blue terror again so. plz tell me what files i have to remove.??
I am also using ICS V3 but no such problem occurs... i have backed up whole nandroid system with sd-ext without any problem....i think problem is different...not a problem of rom....it may be recovery image corrupted... so I suggest that he should flash recovery again via SP tool...:rolleyes:
guyes plz thake this seriously..
my recovery is not doing backup of the sd-ext
while doing backup of sd-ext it suddenly stops and says
e of /sd-ext!
and it also does not generate md5 sums.. so the backup is of no use for restoring coz when we try to restore the recovery gets md5 mismatch of course.!!
- i formatted my sd card in computer but no the recovery doesn't work..
- also i re-flashed the recovey by sp flash tool but the same error again /!!
@mastermind plz help quickly..!!
e of /sd-ext!
Exact same problem for me too.. pls help
e of /sd-ext!
Both of u did u deleted the scriptz folder from ur memory card if not then do it right now if u dint know which folders to delete then just delete all the folders which u dint recognised as system created folder or u created and then go in recovery and see ur sd ext backup will work. if still :confused: then provide the names of the folder what u have in ur memory card will let u know which one to delete.
buddy i got it working.!!
i don't know what happened but my sd-ext got corrupted .!! Link2sd was detecting it.! but the recovery was not.!!
so what i did was..
1) backuped all memory card in pc and formatted the card through the pc.!!
2) formatted my sd-card from recovery as well as from the phone settings storage.!!
3) repartitioned my sd-card and then reflashed blue terror .!!
then when i tried to backup i got it all working superfine again..
thanks to those who helped..
so what i did was..
hey m still stuck at the some problem..
I did exactly what you did bt still same issue..
any help??
Are u on blue terror or some other ROM?
yes on Blue Terror..
Folders in my SD Card:
.android_secure
.tubemate.
.vAd
Android
clockworkmod
data
DCIM
download
holo launcher
Images
LOST.DIR
media
Movies
romtoolbox
TitaniumBackup
Video
WhatsApp
Where will be script folder that you were mentioning once needs to be deleted?
